mdlIModelClient SetGlobalOption
Sets a global option for all MotionView clients.
mdlIModelClient_Handle SetGlobalOption option, value
MotionView Tcl Modify
This command sets a global option for all MotionView clients. A global option is an option that spans all model clients. For example, when you set an option in one model client, and you get that option in another model client, it reflects what you set in the first model client.
option
The list of various available options are:
meshlinecolor_idx
Index of the color for mesh lines.
foreground_idx
Color index for foreground items, such as text.
background_idx
Color index for the top of the background.
background2_idx
Color index for the bottom of the background.
axis_xcolor_idx
Color index of the triad's x axis.
axis_ycolor_idx
Color index of the triad's y axis.
axis_zcolor_idx
Color index of the triad's z axis.
specular_color_idx
Color index used for the material's specularity (the color the material displays when it is shiny).
parametric_editbox_color_idx
Color index of the parametric text box.
gradient_type
Type of gradient used in Graphics Window.
draw_triad
Display the Global Frame implicit graphic.
draw_model_title
Display the model file name in the Graphic Window.
zoom_factor
Magnitude of how much a model can be zoomed in or out.
simplify_bgfg_on_capture
True if activated, otherwise False.
material_shininess
Index of the material shininess (0-128).
pick_aperture
Index of the option selected.
check_general
Check general model information for Reference errors whenever a CheckModel is run.
check_DOF
Check and display Degrees of Freedom when a user does a CheckModel.
check_files
Check and display all the files being used by a Model, whenever a CheckModel is run.
check_data
Check and display suspect data for any errors whenever a CheckModel is run. For example, a free body (which is not attached to Ground in any way) will be listed in Suspect Data whenever a CheckModel is run.
wizard_menu_state
Enable or disable the Wizard Menu state. 'True' will enable the menu state and 'False' will disable it.
mv_last_dir
Last directory used by MotionView.
mv_write_anim_file
Save the .maf file (or not). If 'True', the .maf file will be created. If 'False' no .maf file will be created.
value
This is the value to be set against the ‘option’ key.
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetGlobalOption meshlinecolor_idx 1
mcl SetGlobalOption foreground_idx 2
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
Returns 0 if successful, otherwise an error code.
