mdlIDataMember GetRawExpression
Gets the raw expression used to specify the value of the current data member.
mdlIDataMember_handle GetRawExpression
MotionView Tcl Query
This command returns the expression used to specify the value for the data member.
To get the expression used to specify the value for the mass data member:
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle body_mass_handle b_piston.mass
body_mass_handle GetRawExpression
body_mass_handle ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
None.
