HMMOD_nodesetactive()
Sets the status of a node to active or inactive.
void HMMOD_nodesetactive(void * nodeptr, int active);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
active
The status of the node. Settings are:
  • 0 - Inactive
  • 1 - Active
This function allows you to determine which nodes in the element are used for averaging; all nodes with an active status are used. The default setting for nodes is active.
None.
