HMMOD_elementsetactive()
Sets the status of an element to active or inactive.
void HMMOD_elementsetactive(void * elementptr, int active);
HyperMesh hmmodlib Function
elementptr
The pointer to the element.
active
The status of the element. Settings are:
  • 0 - Inactive.
  • 1 - Active.
This function allows you to determine which elements in the model are used for averaging; all elements with an active status are used. The default setting for elements is active.
None.
