HMMOD_nodegetcords()
Retrieves the coordinates of a node.
void HMMOD_nodegetcords(void * nodeptr, float * x, float * y, float * z);
HyperMesh hmmodlib Function
nodeptr
The pointer to the node.
x
The x coordinate of the node.
y
The y coordinate of the node.
z
The z coordinate of the node.
The x, y, and z variables are set to the coordinates of the specified node.
None.
