HMMOD_elementgetintegrationpointresult()
Retrieves the integration point result of an element specified by element pointer, integration point, layer and index.
float HMMOD_elementgetintegrationpointresult(void * elementptr, int layer, int integrationpoint, int index);
HyperMesh hmmodlib Function
elementptr
The pointer to the element.
layer
The layer where the integration point result is.
integrationpoint
The integration point where the result is.
index
The index to the array of integration point results.
The integration point result at the specified element.
None.
