HMMOD_nodefindifexists()
Retrieves the pointer to a node if it exists.
void * HMMOD_nodefindifexists(HM_entityidtype id);
HyperMesh hmmodlib Function
id
The ID of the node to be located.
A pointer to the node identified by ID.
This function does not issue error messages when a node is not found and in this case returns NULL. You must check for a NULL pointer before using the return value.
None.
