HMMOD_elementfind()
Retrieves the pointer to an element.
void * HMMOD_elementfind(HM_entityidtype id);
HyperMesh hmmodlib Function
id
The ID of the element to be located.
A pointer to the element identified by ID.
This function does not issue error messages when an element is not found and in this case returns NULL. You must check for a NULL pointer before using the return value.
None.
