10.0-SA1-100 API Programmer's Guide
Radioss Set ID Pools
Starting with version 10.0-SA1-100, HyperWorks Desktop supports Set Id Pools for Radioss. If you have a Tcl script that operates for the Radioss user profile, this script may need some modifications as below:
  • If you are using the *renumber command to renumber Radioss sets, switch to the *renumbersolverid command.
  • If you are displaying the set IDs in a GUI, please get the solver ID corresponding to the internal ID using the command hm_getsolverid $internalid and then display the solver ID.
New Commands
Modified Commands
  • General/Core
    • hm_framework - New event before_exit added for registerproc, unregisterproc and getregisteredprocs arguments.
    • hm_getentityarray - Has been updated with the following data names:
      • components: connectors, elements, lines, nodes, points, solids, surfaces
      • contactsurfs: face_indicies, reversecode
      • elements (all configs): nodes
      • rbe3 elements: independentcoeffs, independentdof, independentnodes
      • rigidlink elements: dependentnodes
      • groups: elements
      • outputblocks: assemblies, components, elements, groups, materials, nodes, properties, sets, systems
    • hm_getentityvalue - Has been updated with the following data names:
      • beamsections: collector
      • blocks: systemid
      • cards: name
      • gap elements: length
      • rigidlink elements: dependentnodesetid
      • loads: mappedid
    • *createmark/*appendmark/hm_createmark/hm_appendmark - Have been updated with the following selection methods:
      • assemblies "by comp"
      • assemblies "by comp id"
      • assemblies "by comp name"
      • assemblies "by component"
      • assemblies "by component id"
      • assemblies "by component name"
      • assemblies "by outputblock"
      • assemblies "by outputblock id"
      • assemblies "by outputblock name"
      • assemblies "by multibody"
      • assemblies "by multibody id"
      • assemblies "by multibody name"
      • beamsections "by collector"
      • beamsections "by collector id"
      • beamsections "by collector name"
      • curves "by plot"
      • curves "by plot id"
      • curves "by plot name"
      • elements "by node"
      • elements "by node id"
      • elements "by set"
      • elements "by set id"
      • elements "by set name"
      • nodes "by elem"
      • nodes "by elem id"
      • nodes "by element"
      • nodes "by element id"
      • nodes "by set"
      • nodes "by set id"
      • nodes "by set name"
      • outputblocks "by assem"
      • outputblocks "by assem id"
      • outputblocks "by assem name"
      • outputblocks "by assembly"
      • outputblocks "by assembly id"
      • outputblocks "by assembly name"
      • outputblocks "by comp"
      • outputblocks "by comp id"
      • outputblocks "by comp name"
      • outputblocks "by component"
      • outputblocks "by component id"
      • outputblocks "by component name"
      • outputblocks "by elem"
      • outputblocks "by elem id"
      • outputblocks "by element"
      • outputblocks "by element id"
      • outputblocks "by group"
      • outputblocks "by group id"
      • outputblocks "by group name"
      • outputblocks "by material"
      • outputblocks "by material id"
      • outputblocks "by material name"
      • outputblocks "by node"
      • outputblocks "by node id"
      • outputblocks "by property"
      • outputblocks "by property id"
      • outputblocks "by property name"
      • outputblocks "by set"
      • outputblocks "by set id"
      • outputblocks "by set name"
      • outputblocks "by system"
      • outputblocks "by system id"
      • sets "by assem"
      • sets "by assem id"
      • sets "by assem name"
      • sets "by assembly"
      • sets "by assembly id"
      • sets "by assembly name"
      • sets "by comp"
      • sets "by comp id"
      • sets "by comp name"
      • sets "by component"
      • sets "by component id"
      • sets "by component name"
      • sets "by elem"
      • sets "by elem id"
      • sets "by element"
      • sets "by element id"
      • sets "by ellipsoid"
      • sets "by ellipsoid id"
      • sets "by ellipsoid name"
      • sets "by material"
      • sets "by material id"
      • sets "by material name"
      • sets "by mbjoint"
      • sets "by mbjoint id"
      • sets "by mbjoint name"
      • sets "by mbplane"
      • sets "by mbplane id"
      • sets "by mbplane name"
      • sets "by multibody"
      • sets "by multibody id"
      • sets "by multibody name"
      • sets "by node"
      • sets "by node id"
      • sets "by property"
      • sets "by property id"
      • sets "by property name"
    • *findmark - Has been updated with the following selection methods:
      • assemblies attached to components
      • components attached to outputblocks
      • components attached to sets
      • elements attached to outputblocks
      • elements attached to sets
      • groups attached to outputblocks
      • groups attached to sets
      • loads attached to sets
      • nodes attached to outputblocks
      • systems attached to outputblocks
    • *positionmark - Updated to support groups for rigidwall entities.
    • *reflectmark/*reflectmarkwithoption - Updated to support groups for rigidwall entities.
    • *rotatemark - Updated to support groups for rigidwall entities.
    • *scalemark/*scalemarkwithsystem - Updated to support groups for rigidwall entities.
    • *transformmark - Updated to support groups for rigidwall entities.
    • *translatemark/*translatemarkwithsystem - Updated to support groups for rigidwall entities.
    • *compressreal() - Added new option 3 to disable writing 'E' or 'e' and any leading zeros on the exponent.
Deprecated Commands
