Visualize the Boundaries of a Clipped Part
Visualize the boundaries of the clipped part of the model by using the Clipped geometry options.
  1. From the Display toolbar, click Section Cut .
  2. In the Section Cut panel, activate the Features check box to display the feature lines of the clipped part of the model.
  3. Activate the Transparent check box to display the clipped part of the model as a transparent surface.
