The Synchronize Windows tool allows you to manipulate the view matrix of multiple models in multiple windows at the same
time and supports the synchronization of the axis range settings of multiple 2D plotting windows on the same page.
The Boundary Geometry option on the Display Control menu on the toolbar allows you to visualize the boundaries of the model regardless of whether or not entities are displayed.
The Mask panel allows you to mask elements, components, and systems to reduce the number of entities displayed on the
screen. With fewer entities displayed on the screen, it is easier to pick the necessary elements or visualize important
areas of a model.
Symmetry visualization allows partially modeled geometry to be shown in full extent by reflection and/or duplication
or in the case of axisymmetric models, by 3D geometry generation.
Realistic Rendering is a new graphics mode that is based off of the physically based rendering model approach that allows
for the flow of light to be rendered more accurately as it would be in the real world.
The Display Control menu on the Display toolbar
allows you to select the attributes to display on the model.
A check mark indicates that the attribute is displayed. For
example, if notes are displayed on the model, then Notes on the Display Control menu will have
a check mark next to it (see the example below):
Figure 1. Display Control Menu
To turn off the attribute in the window, select the option from the display control
menu. This does not affect or remove any attributes defined for the model in the panel
selected. The following options on the Display Control menu can be used to toggle features
on and off in corresponding panels, dialogs, and menus:
Tracing
Tracking
Contour
Iso Value
Tensor Plot
Vector Plot
Legend(s)
Section Cuts
Measures
Notes
Sets
Exploded View
Symmetry
Axisymmetry
System Plot
FBD Plot
SCL
Perspective
Boundary Geometry
Perspective
The Perspective option on the Display Control menu on the toolbar allows you to display graphics using true 3-D perspective.
Boundary Geometry
