Perspective
The Perspective option on the Display Control menu on the toolbar allows you to display graphics using true 3-D perspective.
Graphics can be displayed using a Small Angle (10 degrees), Medium Angle (25 degrees), Large Angle (40 degrees) or Custom (5 - 45 degrees) perspective. In addition, the perspective can also be turned off.
Figure 1. Perspective Option on the Display Control Menu
