Access the Context Menu
  1. From the Display toolbar, click Section Cut .
  2. From the Section Cut panel, right-click anywhere within the Section Cuts list.
    The context menu is displayed.
  3. Click on one of the available options.
    Delete Deletes the selected section cut(s) from the list.
    Rename Displays the Rename dialog, which allows you to rename the selected section cut.
    Show Displays the selected section cut(s) in the graphics area and activates the corresponding check box(s).
    Hide Hides the selected section cut(s) in the graphics area and deactivates the corresponding check box(s).
    Show Manipulator Displays the Graphical Manipulator for the currently selected section cut in the graphics area. The Section Cut Graphical Manipulators allow you to modify the definition of section cuts, as well as translate or rotate sections anywhere in 3-D space.
    Hide Manipulator Hides the graphical manipulator for the currently selected section cut in the graphics area. See the Display State of Graphical Manipulators topic for additional details.
