Remove Load Cases or Simulations from a Derived Load Case
  1. Do one of the following:
    • From the Results toolbar, click Derived Load Steps .
    • Select Create > Derived Load Steps from the Results menu.
    • Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
    The Create/Edit Derived Load Case dialog is displayed.
  2. Select one or more simulation time steps from the derived load case list.
  3. Click the left blue arrow (remove button).
    The simulation time steps are removed from the list.
