Delete a Derived Load Case
  1. Do one of the following:
    • From the Results toolbar, click Derived Load Steps .
    • Select Create > Derived Load Steps from the Results menu.
    • Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
    The Create/Edit Derived Load Case dialog is displayed.
  2. Select a load case from the Derived load case drop-down menu in order to make it active.
  3. Click Delete.
    The last derived load case that remains in the list becomes the active derived load case.
