Learn how to perform a DOE study using HyperStudy and the HyperStudy Job Launcher within HyperMesh. HyperMorph is used to parameterize the shape of the design.
The goal of this tutorial is to see how head impact simulation following the pedestrian safety regulation EuroNCAP
can be defined using the Pedestrian Impact tool starting from a full vehicle model.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
In this tutorial you will create a seatbelt system and all related solver seatbelt
entities.
This tutorial uses the SEAT_MODEL_HM2020.HM file that can be found
in the <hm.zip>. Copy the file(s) from this directory to your
working directory.Figure 1.
