HM-2030: Simplify Geometry
In this tutorial you will change the shape of parts and simplify geometry.
This exercise involves changing the shape of a part in order to simplify the geometry. Certain details of the shape, such as small holes or blends, may simply not be necessary for the analysis being performed. When these details are removed, the analysis can run more efficiently. Additionally, mesh quality is often improved as well. Changing the geometry to match the desired shape can also allow a mesh to be created more quickly.
In this tutorial you will learn how to:
  • Mesh the clip, review the mesh quality, and determine the features to be simplified
  • Remove surface fillets
  • Remove edge fillets
  • Remove pinholes
This exercise uses the clip_defeature.hm file, which can be found in the hm.zip file. Copy the file from this directory to your working directory. This model file contains geometry that has been midsurfaced. Surfaces have been created on the mid-plane of the part.
The model is using an element size of 2.5. You can assume a simple structural analysis will be run on the part, and thus does not require much detail. There are unnecessary features in this model that can also be removed.
Open the Model File
In this step you will open the model file.
  1. From the menu bar, click File > Open > Model.
  2. In the Open Model dialog, open the clip_defeature.hm model file.
Turn Off the Display
In this step you will turn off the display of the lvl10 component.
If the lvl10 component is displayed, it needs to be turned off so that you can easily work on the midsurface geometry.
In the Model Browser, Component folder, click next to lvl10 to turn off its geometry display.
Mesh the Clip
In this step you will mesh the clip to view mesh quality before defeaturing.
  1. To shade the model's geometry and surface edges, click on the Visualization toolbar.
  2. To open the AutoMesh panel, click Mesh > Create > 2D AutoMesh from the menu bar, or press F12.
  3. Set the entity selector to surfs.
  4. In the element size= field, type 2.5.
  5. From the mesh type list, select mixed.
  6. Toggle the meshing mode from interactive to automatic.
  7. Verify that the elems to surf comp toggle is set.
  8. To select all of the displayed surfaces, click surfs >> displayed.
  9. Click mesh.
    HyperMesh generates the mesh preview.
  10. To exit the panel, click return.
Review Mesh Quality
In this optional step you will review the quality of the mesh that was created.
This step is optional. Pay attention to the areas that have an irregular, poor quality mesh. An irregular, poor quality mesh generally contains rows and columns of quads that are not neat. You will use the Check Elements panel to evaluate the minimum length check of the elements.
  1. To open the Check Elements panel, click Mesh > Check > Elements > Check Elements from the menu bar, or press F10.
  2. Go to the 2-d subpanel.
  3. In the length < field, type 1.
  4. To evaluate the minimum length, click length. Many of the elements that failed the length test are located around the fillets of this model.
    Note: For better visualization of element quality, you may need to display the geometry in wire frame mode by clicking on the Visualization toolbar.
    Figure 3.
  5. To exit the panel, click return.
Remove Pinholes
In this step you will remove four small pinholes.
Pinholes are closed free edge loops within a surface. Pinholes do not need to be circular.
  1. To open the defeature panel, click Geometry > Defeature > Pinholes from the menu bar.
  2. In the diameter < field, type 3.0.
  3. Select surfs >> all.
  4. Click find.
    HyperMesh identifies all of the pinholes that have a diameter of 3 or less in the model and places a white xP symbol in their centers.
    Figure 4.
  5. Click delete.
    HyperMesh removes the selected pinholes in the model and replaces them with fixed points located at the center of the original pinholes. The mesh also updates according to the changes in the geometry.
Remove Surface Fillets
In this step you will remove all surface fillets in the clip.
  1. Go to the surf fillets subpanel.
  2. If the model's geometry and surface edges are not shaded, click on the Visualization toolbar.
  3. Under find fillets in selected, click surfs >> displayed.
  4. In the min radius field, type 2.0.
  5. Click find.
    HyperMesh identifies all the surface fillets with a radius of 2 or greater in the model.
    Figure 5.
  6. Click remove.
Identify and Remove Rounded Corners
In this step you will automatically identify and remove rounded corners of surfaces.
You should still be in the Defeature panel.
  1. Go to the edge fillets subpanel.
  2. Click surfs >> displayed.
  3. In the min radius field, type 1.0.
  4. To find all fillets in the model, set the bottom switch to all.
  5. Click find.
    HyperMesh identifies all of the edge fillets that meet the filter criteria and displays an F symbol where they are located in the model along with radial lines.
  6. With the fillets entity selector active, right-click on one of the F fillet markers on the screen to deselect the fillet.
  7. Click remove.
    HyperMesh deletes all the selected edge fillets except for the one which was deselected in Step 6.
Save Your Work
In this optional step you will save your work.
Now that the model has been simplified, it is a good time to save the model.
Optional: From the menu bar, click File > Save > Model.
The model is now represented in a much simpler form that suits the analysis that will be performed. Holes, surface fillets, and edge fillets were removed that were considered too small to be captured by the desired element size of 2.5.
