Report outputs and visualization configuration.
Settings
- advance
- true = Advance style report with MultiCPU, false = Normal style report
with 1CPU.
- Supported values: true
- avoid_duplicate_slide
- true = duplicate slides avoided, #duplicate issues shown under instance,
false = all of the issues for single pairs will be reported.
visualization settings define configurations related to visualization.
- bg
- Background colors to be used for creating H3D files and images.
- h3d
- The background color to be used when creating H3D files.
- Supported values: 255, 255, 255, 255, 255 255
- jpg
- The background color to be used when creating JPG image
files.
- Supported values: 49, 111, 255, 95, 181 266
- color
- Default colors for various check results.
- comparison
- Default colors for comparison check.
- master
- Color number for Master component.
- Supported values: Color Number, ex - 12
- slave
- Color number for Slave component.
- Supported values: Color Number, ex - 6
- unmatched
- Color number for unmatched entities.
- Supported values: Color Number, ex - 33
- WT-Calculation
- Option to display the weight in the reports.
true - will enable the display and false - will
disable the display.
- Supported values: true or false
- WT-Comparison
- Option to display the delta weight in the
reports. true - will enable the display and false
- will disable the display.
- WT-Graph
- Option to display the weight graph in the
- WT-Graphtype
- Option to choose the waterfall graph type. The
values 0 / 1 / 2 / 3 represent the available graph
types.
- Supported values: 0, 1, 2, 3
- WT-Scalefactor
- Multiplies the weight with the specified
multiplication factor.
- Supported values: A desired multiplication
factor. Default is 1.
- intersection
- Default colors for intersection test.
- master
- Supported values: Color Number, ex - 55
- slave
- Supported values: Color Number, ex - 21
- master-intersecting
- Color number for intersecting elements on the
master component.
- Supported values: Color Number, ex - 62
- slave-intersecting
slave component.
- Supported values: Color Number, ex - 47
- transparency
- Transparency settings.
- intersection
- Transparency settings for intersection check.
- master
- The choice to turn on transparency for the
master component. True enables transparency and
false makes the component opaque.
- slave
- The choice to turn on transparency for the main
component. True enables transparency and false
- level
- The level of transparency on a scale of 0 to 10.
0 being no transparency and 10 being completely
transparent.
- Supported values: Number, ex - 3
- comparison
- Transparency settings for comparison.
- level-assembly
- The level of transparency on a scale of 0.5 to
5, with 0.5 being high transparency and 5 being
less transparent.
- intersection
- Visualization related settings for intersection reporting.
- cross
- Settings related to Cross.
- length
- The length of the cross as a percentage of the
model length.
- Supported values: Percentage, ex - 8
- width
- The width of the cross as a percentage of the
model length.
- Supported values: Percentage, ex - 0.15
- sphere
- Sphere dimension for the sphere.
- radius
- The radius of the sphere as a percentage of the
cross length.
- Supported values: Percentage, ex - 2
- color
- The color to be used for the sphere by
specifying the corresponding color number from the
palette.
- Supported values: Percentage, ex - 3
- reportgroup
- multiple = Multiple slides in single PPT.
- Supported values: single / multiple
- spotweld
- Setting related to spot weld check reporting.
- cross
- Settings related to cross.
- length
model length.
- width
model length.
- sphere
- radius
- The radius of the sphere as a value in model
units.
- color
palette.
- clip
- Clip dimensions.
- radius
- Attribute - TBD.
- Supported values: Value in model units, ex -
150
- hvp
- DO NOT CHANGE.
- Supported values: Text Value, ex – HvpLeft, HvpRight
- bordercolor
- Border color of the HVP title note.
- titlefontsize
- Title font size.
- titlecolor
- Title Color.
- titlefont
- Title Font.
comparisonunified settings:
- max-record
- Supported values: 50
- template
- The file name of the MS PowerPoint template to be used for reporting.
- Supported values: File name, ex –
“Template_compare.potx”
- template-sheet
- Name given to template.
- skip-thumbnail-slide
- Parameter to skip second page of Comparison PowerPoint and Excel
report.
- skip-thumbnailassemblyimage
- Parameter to skip assembly image in Comparison PowerPoint
(checkbox).
- template-ppt
- Path of the power point template.
- percentage-sequence
- This is the parameter for arranging the order of thumb nail images of
components in the PowerPoint.
- Supported values:
- 0 – Default order.
- 1 – Match percent in decreasing order.
- 2 – Part IDs in decreasing order.
- resultslide
- This is the parameter to get the default multiple slides for
multi-variant comparison or to get single slide which shows the best
match result.
- Supported values:
- Default – Multiple slides are shown.
- Best match – Best matches for each components are shown from
the multiple variants.
- threshold_report
- This is an intermediate percentage value to be given between threshold
value and maximum value. The components having match percent value
between threshold and threshold_report value is shown in green color and
the components with value between threshold_report and maximum value in
gray color.
- result-review
- Result display setting after comparison check is completed. The
following options can be selected to display unmatched entities on
graphics.
- tempNodes
- Displays unmatched area as temp nodes.
- tempComps
- Displays unmatched area as elements in red color.
- tempComps+Node XYZ
- Displays unmatched area as elements in red and exports
unmatched nodes in a text file working folder.
- legend-detailed
- Applicable for Quick Comparison flag ON, unmatched elements
are shown in red color.
- legend-overview
are not shown in red color showing high level results.
- range-legend-level
- Applicable for Quick Comparison flag ON. Comparison legend left tab
Ranged's number of levels are controlled by these values. 0 to 100%
values are split by these values. An example in case of 30-90% match
results exist, 90-30/7=8.57 splits will be shown.
- threshold-ranges
- Applicable for Quick Comparison flag ON. Comparison legend right tab
Discrete's levels are controlled by these values. The accepted value is
from 30 to 99.9 with spaces between values.
- Default: 50 80 90 (result legend will display 0-30, 30-50, 50-80, 80-90,
90-100. Specific range will be ignored if no results found).
- thumbnail-assemblyImageColor
- Applicable for quick Comparison flag ON. Part color shown inside the
assembly thumbnail image, it is in the 2nd page of the Powerpoint
report.
- Default: Dark blue.
- thumbnail
- Text displayed below thumbnail image, supports PID or Part Name. It is
in the 2nd page of the Powerpoint report.
- Default: PID.
- Show unmatched ribs
- Parameter to display unmatched surfaces for the Honeycomb kind of Rib
pattern. The default is OFF.
Intersection settings are related to reporting for intersection check.
- max-slide
- Maximum number of slides to be included in the PPT file.
- Supported values: Number (for example, 50).
- ignore_part_Instance
- Ignores part instances from intersection check and report. This is
applicable if the number of parts in the model are more then 300.
- Default: ON.
- ignore_name_Instance
- Ignores parts if their Part Names and Part Number are almost the same
from intersection check and report. This is applicable if the number of
- Default: ON.
- display_intersection_depth
- Displays intersection depth value in a text box inside HyperView player.
- Default: OFF.
- text-static
- You can enter the information.
- Supported
values:
object: “Text left”
description: “Intersection Check”
object: “Text right”
description: “Answer:”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
spotweld settings:
- max-slide
- Supported values: Number,ex-50
- text-static
- Supported values:
object: “Text left”
description: “Spotweld Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
spot-comparison settings:
- max-slide
- template
reporting.
“Template.potx”
- text-static
- Supported values:
object: “Text left”
description: “Spotweld Comparison”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
freepart settings:
- max-slide
- template
“Template.potx”
- layout
- DO NOT CHANGE.
- Supported values: Number, ex – 2
- text
- description
- DO NOT CHANGE.
- Supported values: Text Value, ex – “Text1”
- project
- DO NOT CHANGE.
- Supported values: Text Value, ex – “Info1”
- id
- DO NOT CHANGE.
- Supported values: Text Value, ex – “Info7”
- date
- DO NOT CHANGE.
- text-static
- Supported values:
object: “Text left”
description: “Connection Check”
object: “Info3”
description: “_”
object: “Info4”
description: “_”
object: “Info5”
description: “_”
object: “Info6”
description: “_”
