Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
After the check, groups are created under the Part Browser/Part
Set Browser. To execute the classification, parts are mandatory. Select the root
part from the Verification Browser or the Comparison Browser and run Classify.
From the Verification Browser/Comparison Browser, right-click and select Parts > Match from the context menu.
From the Method drop-down menu, select either AI or
Shape.
In the Similarity (%) field, type the desired same shape match%. The default is
50%.
In the Tolerance field, type the search tolerance to use to find matching
entities. The default is 0.1mm.
In the Max Area field, type the maximum area to search.
In the Min #Surface field, type the minimum number of surfaces to use.
