Open the Verification Browser
Use the Verification Browser to inspect CAD data supplied from your design or CAD team.
The Verification Browser supports Offset, Intersection, Spot Weld, Connection, Spot Comparison, and Free Part checks. After performing the verification, results are exported to reports.
From the menu bar, click View > Browsers > HyperMesh > Verification.
The Verification Browser opens.
Browser User Interface
Overview of the Verification and Comparison Browser user interfaces.
The Verification and Comparison Browsers consists of a search, filter, column data and Entity Editor.
You can switch to the Part Browser any time to perform detailed operations on a part.
Column Details
By default, the following attributes are listed as columns in the first pane.
Name
ID
Part assembly and model IDs.
Color
Part entity colors.
MVD Part Name
Part entity name.
MVD PID
Entity specific property ID’s. At the part level, the IDs for referenced properties are displayed. At Component level, IDs of the referenced properties are displayed.
UID
Part assembly and part Unique IDs.
MVD Revision
Major revision, Study revision, and Library Part revision.
MVD Material
Material name of the part.
MVD Design Material
Design material from CAD metadata.
MVD Thickness
Entity specific thickness. At the part level, it displays the thicknesses of the referenced properties. At component level, it shows the thickness of the referenced property.
MVD Design Thickness
Design thickness from CAD metadata.
MVD Contact Thickness
Contact thickness from CAD metadata.
MVD Material Query
0 or 1.
MVD Vendor
String of vendor names – you must write some text for reference.
MVD Action
Type of operation for the part entity.
MVD Modeling Type
Type of modeling – either mid-plan or skin mesh for the part entity.
MVD Status
String of text – you must write some text for reference
MVD Mesh Size
Mesh size for the part entity.
MVD Solver
Solver name string – you must write the value.
MVD PID Rule
Keep existing or incoming IDs.
MVD Match %
Similarity value of both parts. For detailed calculation, see Generate Comparison Results.
MVD Base PID
Part ID of the CAD/FE part that is topologically matching.
MVD Base Material
Material name of the CAD/FE part that is topologically matching.
MVD Base Thk
Thickness value of the CAD/FE part that is topologically matching.
MVD Error
Errors accrued in respective operation on the part.
MVD Function Name
Sub assembly name of the part.
MVD Assembly Name
Assembly name of the part.
MVD Counter Parts
Matching or intersecting part’s UDMID.
MVD Bounding Box
Bounding box of the part.
MVD Oriented Bounding Box
Oriented bounding box of the part.
MVD Weight
Weight of the part.
MVD Delta Weight
Weight difference between part and counter part.
MVD Load Collectors
Load collector card name of the part.
MVD Contacts
Contact card names of the part.
MVD Boundary Conditions
BCs card names of the part.
MVD Representation File
Default representation file path of the part.
Context Menu
Overview of the Verification and Comparison Browser context menus.
Name
Import
Import CAD or FEM as a BOM file into the Verification Browser for manual cleanup, and then run verifications. It is recommended to use a respective check in case no data cleanup in necessary, as this Import function is integrated into each verification function.
Export
Export an .xml file to a specified location. You can use this .xml file to run Model verification using the XML option.
Check
Check functions. For more information, refer to Perform Model Checks.
“Check (Comparison, Representation Comparison)”, “Multiple Checks".
Parts
Consists of part functions.
“Count”,”Rename”, “Renumber” “Export”, “Delete” , “Load”, “Load in other”, “Load in HyperView Player”, “Unload".
Representations
Consist of representation import options “Load”, “Load in other HM”, “Load in Hyper View Player”, “Unload”, and “Save”.
Review Results
Comparison and Intersection results are directly displayed in HyperMesh graphics. For Comparison function, you can right-click Base Part and select review to display the base part and matched variant parts in the graphics area along with mismatched area with temp nodes.
CSV
Compare
Compare and identify unmatched information between a CSV file and the imported BOM file. Results will be populated in the Error column. The CSV file header details can be configured through the Configuration option, under the CSV comparison section.
Export
Export selected parts and children parts in to a CSV file.
Update
Read a CSV file exported with the Export function, and update the information displayed in the Verification browser. The Entities column is the reference column considered for updating the BOM.
Tools
Consist of “Divide Slides”, “Open In Explorer”, “Reset Results”, “Get Revision menus”, details are available in the functional detail sections.
Configuration
Open the configuration dialog.
