Add and Remove List Items
Steps on how to add and remove list items.
- Category - bolt, nut, unwanted or others.
- Property - *bolt, *nut or *clip.
View new features for HyperMesh 2021.
Discover HyperMesh functionality with interactive tutorials.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Use the Verification Browser to inspect CAD data supplied from your design or CAD team.
Use the Comparison Browser to compare and identify the topology difference between two models/part assemblies/parts.
Import a model using Model Verification.
Perform various model checks in the Verification Browser.
Overview of various settings that can be configured for Model Verification.
Specify default values for Model Verification .log file settings.
Specify defaults for CAD model import file extensions.
Specify defaults for FE model solver types, version and file extensions.
General defaults for the Model Verification instance.
Defaults for the offset functionality of Model Verification.
Default values for the offset functionality of Model Verification.
Configurations for the intersection check functionality.
Specify defaults for the spotweld check functionality of Model Verification.
Connection check configurations.
Spot comparison check configurations.
Free part check configurations.
CSV comparison tool compares CAD/FE attributes against CSV file column.
Naming conventions used in various Model Verification Modules.
Report outputs and visualization configuration.
Save Representations in the input folder.
Configure any part.
Review the selected Part Assembly/Part in HyperView Player.
Review the selected Part Assembly/Part in HyperMesh graphics.
Export part representations.
Rename and set PIDs for all parts.
Renumber PIDs for all parts.
Get the count of the selected Part Representations.
Group parts based on size and shape.
Run Model Verification operations in batch mode.
Limitations of the Model Verification tool.
Use the curve editor to create and plot XY curves.
HyperMesh composites modelings.
