Data Import/Export
Supported CAD readers and writers for CATIA and FiberSim.
CATIA Composites Link Reader
Use the CATIA Composites Link option to import drape data. This method is separate from the CATIA reader, where drape data is not imported.
- Import a CAD model (without composite data) using the CATIA geometry import method.
- Use the CATIA Composites Link connection to import the HDF5 files created from the Simulayt interface in CATIA.
- When realizing the plies, use the CATIA Composites Link drape map by proximity method in the Ply Realization dialog.
- When exporting the composite data to CAD including draping, use the geometry export option CATIA Composites.
CATIA Composites Link Writer
Use the CATIA Composites Link option to export composite drape data.
FiberSim Reader
Supported Entities
- Plies
- Name, thickness, and fiber orientation information is directly read and mapped as a Ply entity. Plies that point to woven and stack materials are split/separated into multiple plies with half the thickness and correct orientation angles. These split ply names always have _1 and _2 suffix in them for each identification.
- Date Map/Table
- Data map with element set (ply shapes), material orientation angles (orient1 , orinet2 , draping corrections) thickness corrections, reference direction and normal information for each ply is preserved/mapped in the table entity, therefore each ply has a table associated with it. Nodes and elements are not created in the database from FiberSim triangulation data to define ply shapes. Instead, it preserves this information in a table so that when these plies are mapped (realized) on actual good mesh, HyperMesh uses this triangular information to define the ply boundary and extract the actual elements.
- Laminates
- One laminate per HDF5 component with all the ply sequence preserved as per layer_id value.
- Materials
- Material names and their mechanical properties are read and mapped to solver cards automatically depending on the user profile loaded while importing the model. Currently mechanical properties such as E1, E2, E3, G12, G13, G23, Alpha1, Alpha2 and Alpha_ref temperature are mapped to solver material attributes.
- Rosette/Systems
- All the system definitions available in the HDF5 file will be imported into one system collector. Currently HyperMesh does not preserve the ply and system relation.
FiberSim Writer
Use the FiberSim option to export composite data.
