Configure the Results Browser
Change the entity types, columns, options, and toolbars that are displayed in the Results Browser.
  1. Right-click in the Results Browser and select Configure Browser from the context menu.
  2. Use the Browser Configuration dialog to edit browser options, entities and toolbars.
  3. Click one of the command buttons to close the dialog.
    • Click Apply to append the new settings without closing the window.
    • Click OK to keep the new settings, including those that are not applied, and close the window.
    • Click Cancel to discard the changes that are not applied (keeping previous applied settings) and close the window.
  4. Change the columns/attributes that display in the Results Browser by right-clicking on a column heading and selecting check boxes in the microdialog.
Configuration Options
Options
Auto-fit
Automatically fit the selected items to the modeling window, whether using the context menu, Show/Hide, or Isolate functionality to control the display.
Auto-scroll on selection
Locate/highlight an item in the browser and automatically adjust the browser tree to display the item upon selection. This functionality is only available when an item has been selected in the modeling window.
If this option is not activated, then the item will still be located/highlighted in the browser; however, the browser tree will not automatically adjust to show the selected item.
Entities
Select/change the entity types that are displayed in the Results Browser.
Toolbars
Change loadcase
The Change loadcase toolbar allows you to change the current load case/simulation.
Change model
The Change model toolbar allows you to change the current model.
Find/Filter
The Find/Filter toolbar contains search options that can be used to locate an entity within the browser's tree structure.
