Offset Curves Along the Vertical Axis
  1. Select the curves from the list or pick them from the window.
  2. Activate the Y Offset check box.
  3. Enter the distance to shift the curves in the Y Offset text box.
  4. Click Apply to accept the new scaling values.
    The data is shifted up for positive values and down for negative values.
