Replace Multiple Plot Data Files
  1. From the HyperGraph 2D Tools menu, select Replace Filenames.
  2. From the Replace File dialog, select the file to be replaced in the Files Used list.
  3. Click Open File and select a file to replace the current file (the two files must have the same file structure).
  4. Click Open.
  5. Click Apply.
  6. Repeat steps 2-6 for each replacement.
  7. Click Close.
  8. To undo, click Undo.
