Select a Curve to Edit
  1. From the Modify Curves panel, click the Curves icon at the end of the Curves field.
    The Select Curves dialog is displayed.
  2. Select a curve from the list.
Or
  1. Select a curve using one of the following options:
    All
    Select every curve in the list.
    None
    Deselect all highlighted curves in the list.
    Flip
    Exchange the currently selected curves for the unselected curves in the list.
  2. Click OK.
Or
  1. Pick a curve from the window. This overwrites any existing curve selections.
  2. Hold down the Control key to pick more than one curve from the window.
Or
  1. Type in a curve reference into the Curves text field.
    Note: If the curve you select is valid, the text field turns gray. If it is not a valid curve, an error message is displayed.
