Polar plots allow you to plot complex data and are very similar to HyperGraph 2D complex plots. The polar plot toolbar is displayed when you select HyperGraph 2D from the application menu and the active window is set to the Polar Plot mode, .
HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
From the Define Curves
panel, select a curve from the Curve list or pick a curve from the active
window.
Click Cut from the curve list controls.
The selected curve is removed from the list and is no longer displayed
in the active window. The cut curve can be pasted in any HyperGraph or 3D window.
