Apply Attributes to a Datum Line
  1. From the Datum Lines panel, select a datum line from the datum list or from the screen.
  2. Click the Line Attributes tab.
  3. Select a line type.
  4. Select a line thickness.
  5. Select a line color from the color palette.
    The datum line attributes are changed to reflect your selections.
