Select a Contiguous Range of Data
Select one of the following methods:
  1. Select an type, request, or component from the list while dragging the pointer to include data items above or below the selected type, request, or component.
  2. Hold down the Shift key and select another type, request, or component from the list.
The range of data between the first and second selections is highlighted.
