Element Based Surface
In the Element Based Surface dialog, define and edit the *SURFACE, TYPE = ELEMENT card.
The Element Based Surface dialog contains the following buttons:
Table 1.
Button Action
Surface color Changes the color of the current surface in the display.
Review Reviews the current surface by highlighting in white and displaying it through solid mesh in performance graphics in the window. If the surface is defined with sets, the underlying elements are highlighted. Right-click Review to clear the review selections.
Close Updates the Engineering Solutions database with the optional parameters specified and closes the Element Based Surface window.
