Name
The name of the selected free-body section.
ID
The ID of the selected free-body section.
Color
The color of the selected free-body section
Entity id list
This option is mandatory. Defines a group of elements for standard
section or a cross-section.
Node id list
This option is exclusive for element selection. It is used to define
the nodes that will be included in the free-body calculation. If the
selection is empty, the free-body calculation will use all nodes
belonging to the selected elements.
Resolve in
Defines the coordinate system used in the calculation. Options vary
depending on the solver.
Summation Point Type
Defines where free-body forces and moments will be summed. The
centroid will be calculated based on the nodes that are stored
inside the Node id list. If the Node id list is empty, the free-body
calculation uses all nodes belonging to the selected elements.
Summation Node
Defines a node where free-body forces and moments will be
summed.
Summation Point
Defines the coordinates of the point where free-body forces and
