Density Variation Study
Material stiffness and density is directly affected by the manufacturing process, especially in injection molding for plastic parts.
- Select Parameter - a default selection list that shows the selected parameter. In this case, Density is the value.
- Global Variation % - value entry field to provide the parameter variation range
- Select All, Unselect All, Reverse Selection - parameter list selection options
- Parameter list table - table listing the material density in the model
- Add - to add a parameter variation study to the study table
- Update - to update an existing study parameter
- Parameter Variation Study table - a table listing the study variations created
