HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
The next step in the process is to export the variation studies setup in the previous
task panels. These studies can be executed on HyperStudy to
generate the results. SnRD exports these studies into following files, which are
required by HyperStudy-
TPL
XML
This template file is created with the required parameters that are readable by
HyperStudy. Export option also exports a solver deck(FEM)
file.
The Export Stochastics panels allows you to export these
parameters studies. Below is the Export Stochastics panel.
The Export Stochastics allows you to perform the following
operations -
Select the required Variation Study
Parameter from the table to be exported.
Study Name - to define a study name for the exported
files
Combine All - allows you to select whether the studies
should be combined into a single file or create individual files for the study parameters
Yes - combines all the studies into a single file
No - individual files and folders are created
Type - you have the option to export the study as
Stochastics study
DoE(Design of Experiments) Study
Number of Runs - numerical value which states the number
of runs to converge to a final result
Note: The Number of
Runs value is automatically assinged by
SnRD based on the number of studies and the
number of variables. You need not edit this, but has the freedom to do
so.
Export - file browser option to select the files export
location.
