HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
In this task, you can combine SPCs to form a single
SPCADD loadcollector. The Assign
Constraints task panel is as shown below.Figure 1.
You can perform following operations in the Assign
Constraints task panel -
Select Subcase - to select the required subcase from a
drop down list.
Constraints list table -
All the constraints created in SPC Constraints will be listed in the first
table.
Allows you to select constraint(s) to combine.
You can use the selection options in the table.
Select All
Unselect All
Reverse Selection
Add - to create and add the SPCADD
cards in the second table.
Update -to update a previously created
SPCADD card
Delete Selected and Delete All
options to delete the SPCADD cards from the second
table.
