MPC Add Creation
In this task, you can combine MPCs to form a single MPCADD loadcollector. The MPCADD Creation task panel is as shown below.
Note: SnRD Static workflow does not allow you to create MPCs. Create them manually using HyperMesh options.
Perform following operations in the MPCADD Creation task panel -
  1. Select Subcase - to select the required subcase from a drop down list.
  2. Constraints list table -
    1. All MPCs existing in the model will be listed in the first table.
    2. Allows you to select constraint(s) to combine.
    3. You can use the selection options in the table.
      1. Select All
      2. Unselect All
      3. Reverse Selection
  3. Add - to create and add the MPCADD cards in the second table.
  4. Update -to update a previously created MPCADD card
  5. Refresh - to refresh panel table data
  6. Delete Selected and Delete All options to delete the MPCADD cards from the second table.
Note: The MPCADD task is not covered in this tutorial workflow. You can proceed to Output Request Creation task.
