HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment
stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
After execting the results post processing, the next step is to study the risks of the
squeak and rattle issues. You can perform following operations in the
Relative Modal Contribution panel -
E-Line Selection -
E-Lines - drop down list to select Elines in the
model
Select Pair - drop down list to select the
respective pair, a node on the line or complete line
Select Direction - drop down list to select the
plotting direction for displacement.
Note: By default z
direction will be selected, since the assumption is the relative
displacement will occur and captured in z
direction.
Display Excitation Load - check box option to
view the loading strength plotted in a HyperGraph window. This loading
strength value is taken from Load Creation
Load Time History - to generate and plot loading
time history and relative displacement plots for the selected Eline and
the pair.
Note: Once the time history is loaded in the session, the next
step would be to study the relative modal contributions.
RMC Calculation -
Max Peak - option is enabled only when you are
studying modal contributions based on nodes as the selected pair.
Peak - Value & Time - The plot
highlights the peaks values in relative displacement using
horizontal and vertical dashed lines and also shows labels to
highlight the same.
% of Highest Peaks - option is enabled only when
you are studying modal contributions based on complete ELine as the
selected pair
Enter the percentage value of peaks that you want to study in
the % of Highest Peaks field
Select Top Contributors - option to
select the number of top modes contributing to be plotted and
displayed as bar graphs in descending order of effect.
