Modal Sensitivity
The modal sensitivity study can be performed on complete E-Lines or a selected Node pair belonging to an E-Line. Once the RMC is done and determine the modes that exhibit maximum contribution to the relative displacements that lead to squeak and rattle, you can study the effect of particular mode(s) on the total response. SnRD computes the total response (relative displacement) based on the equation of motion without need to simulate again. This enables to understand the potential of a design change that leads to damping or eliminating a certain mode shape.
Chosen modes can be Included or Excluded from the results and displacements recalculated to observe their effect on the squeak and rattle performance.
To do a modal sensitivity study, you have to select the Modal Sensistivity button in Modal Sensitivity studies tab.
- Select Contributor(s) to - drop down list to select
whether to Include or Exclude a mode for analysis
Figure 2.Input Description Inlcude Includes the selected modes in the recalculation of the displacements Exclude Excludes the selected modes in the recalculation of the displacements - % to include - to define the percentage value of the mode to be considered for evaluation
- Modes - list containing all the modes present in the
result file. You can check the boxes under
Modes
column to select a mode - Plot in same graph - check box to define if the study plot should be plotted in the same graph as the relative displacement
- Analyze - after making the required inputs definition, click to run the analysis and plot the graphs.
