Use the Split: Interactive tool to quickly create fixed points on surfaces and edges, and split surfaces with lines. You can also remove fixed
points from surfaces or surface edges to unsplit them.
Use the Fuse tool to connect discrete topology surfaces/solids/parts. The Fuse tool can be utilized to connect close proximity inputs by defining a threshold.
Use the Split: Planes tool to split lines, surfaces, or
solids.
From the Geometry ribbon, click the Split > Plane tool.
Select Lines, Surfaces, or
Solids from the Target selector on the guide bar.
Select target geometry then define how to split.
Option
Lines or Surfaces
Click Tool on the guide bar.
Use the Vector tool to adjust the
position of the split plane.
Solids
Select Plane, Nodes,
or Points from the Tool selector on the guide bar.
Plane
Left-click to place the plane on the model. Use the
Nodes
On a meshed solid, select nodes to define split
lines.
Points
Select at least three points forming a plane to trim
solids.
Optional: Click the Review button on the guide bar to preview the
split sections, as shown below on the left.
Restriction: Only available when splitting solids with
planes.
Deselect sections by holding Shift and left-clicking
to cut the solid at only the desired locations, as shown below in the
middle. The final result is shown on the right.
Click Split on the guide bar.
Tip:
Select a splitting plane using reference entities or features that are
disconnected from the geometry you want to split, including points in
space.
You can modify your surface selection after selecting a splitting plane.
Split preview lines will update appropriately.
Use snap points to snap the splitting plane to
predefined points on lines and surfaces, such as middle and end points.
Clicking a snap point automatically selects attached surfaces/solids.
