Meshing
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Models can be meshed by defining controls and running batch mesh. You can interactively mesh surfaces in case of failure or specific mesh flow requirements. In addition, individual elements can also be modified manually to fix issues or improve element quality in problem areas.
