2021
View new features for HyperWorks CFD 2021.
Discover HyperWorks CFD functionality with interactive tutorials.
File formats supported by HyperWorks CFD.
Create a new file.
Open a file.
Import an existing file to the current session.
Save all of the data in your current session.
Export FE data in your current session.
Take a screen capture of your model and save it to your working directory.
Set up the simulation model, materials, domains, and boundaries.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
Post-process the simulation results by creating visualizations and measurements.
