Open Files
Open a file.
- If the dialog is associated to a filename entry box, the directory is taken from the path entered in the entry box, instead of using the saved directory.
- Certain dialogs take you to a directory in the installation where the selection would commonly be made, instead of using the saved directory.
- If the directory is not valid, the file dialog opens in the application start-in directory.
Do one of the following:
- From the Home tools, Files tool group, click the Open Model tool.Figure 1.
- From the menu bar, select .
- Press Ctrl + O.
- In the Open File dialog, navigate to your working directory and select the file to open.
- If needed, define any options in the Open Options dialog then click Open.
- To open recently used files, select menu bar.
Click
to pin a file to the list.
from the - Quickly open an .hm file by dragging-and-dropping it from a file browser into the modeling window.
