Scale Parts
Use the Scale tool to resize geometry in your model.
From the Geometry ribbon, click the arrow next to the
Edit tool set, then select Scale.
- Choose an entity type using the selector on the guide bar.
- Select the entities to scale.
Define the origin for scaling in the following ways:
By default, it is set as the centroid of selected geometry.
- Click
in the microdialog and select solids to define the center of origin.
- Click
in the microdialog to manipulate the origin with the Move tool.
- Click
Define the scaling factor.
Click
to use uniform scaling or toggle it off to define the scale for X,Y,Z directions individually.
In the microdialog, enter a scaling
factor.
A factor of 1.5 will produce a part 150% the size of the original.
Click
- On the guide bar, click Scale.
