Use the Surfaces: Patch tool
to create patch surfaces between free lines that are not connected or surface edges. You can
also delete surfaces with this tool.
New surfaces are organized in the same component as the first line selected.
From the Geometry ribbon, click the tool.
To manually patch surfaces, do one of the following:
Tip: After a patch surface has been manually created, it remains
selected. HyperWorks CFD attempts to select the appropriate
tangency setting for the surface created, but you can change the tangency by
clicking on the surface while it is still selected.
To automatically highlight and patch missing surfaces:
Click Find on the guide bar.
Click
and
to cycle
through found surfaces.
Select highlighted surfaces to fix them individually or click
Patch All on the guide bar.
To delete surfaces:
Select the surface(s) you want to delete.
Click the highlighted surface(s) again to delete them.
