Use the Surfaces: Cross Extend tool to extend surfaces to meet each other, or
other target surfaces.
Disconnected surfaces on the same plane cannot be extended using the Surfaces: Cross Extend
tool.
From the Geometry ribbon, click the tool.
- Optional:
On the guide bar, click
to define cross extension
options.
Select the source surfaces.
If the Choose targets option is selected, click the
Target selector on the guide bar then select the target surface(s).
Extend surfaces in the following ways:
- Click Extend on the guide bar.
- Left-click a selected surface.
