Rhino Reader
Supported Entities
- B-rep geometry
Import Options
@AttributesAsMetadata
Value | Description |
on |
Import all generic attributes (global and related to single entities) as metadata. |
off |
Do not import attributes related to single entities. Only import global attributes. |
%attribute1%attribute2%attribute3 |
Import specified generic attributes as metadata. The attribute names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperWorks CFD will recognize it as it is the first character of the string. |
@AvoidThirdPartyConversion
on |
Avoid using the conversion functions provided by third-party (default). |
off |
Use the conversion functions provided by third-party. |
@BodyIdAsMetadata
on |
Assign body identifier as
metadata.
off |
Do not assign body identifier as metadata (default). |
@CleanupTol
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Cleanup Tolerance. |
@ColorsAsMetadata
integer |
Read color attributes of geometric entities as metadata with integer values.
on |
Read color attributes of geometric entities as metadata.
off |
Do not read color attributes (default). |
@CreationType
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
@DensityAsMetadata
on |
Read density value as metadata (default).
off |
Do not read density value. |
@DoNotMergeEdges
on |
Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
@ImportBlanked
on |
Import entities that are hidden, blanked, or no show. |
off |
Do not import entities that are hidden, blanked, or no show (default). |
@ImportCoordinateSystems
on |
Import CAD coordinate systems as system collectors (default). |
off |
Do not import CAD coordinate systems. |
@ImportForVisualizationOnly
on |
Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses. |
off |
Import the model in the normal fashion (default). |
@ImportFreeCurves
on |
Import free curves (wireframe entities) into the model (default). |
off |
Do not import free curves. |
@ImportFreePoints
on |
Import free points into the model (default). |
off |
Do not import free points. |
@LayerAsMetadata
on |
Read layer value as metadata.
off |
Do not read layer value (default). |
@LegacyHierarchyAsMetadata
on |
Generate metadata with the original CAD hierarchy within the
part.
off |
Do not generate metadata with the original CAD hierarchy within the part (default). |
@MetadataPrefix
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming for more details. |
@OriginalIdAsMetadata
on |
Import original CAD entity IDs as
metadata.
off |
Do not import original CAD entity IDs as metadata (default). |
@ScaleFactor
double |
Define the model scaling factor during import. Default is 1.0. |
@ShrinkSurfaces
on |
For trimmed surfaces, shrink the corresponding base surfaces to only enclose the extents of the external trimming contour, plus a narrow frame. |
off |
Do not modify the base surfaces (default). |
@SkipCreationOfSolid
on |
Read surfaces, but do not create solid entities. |
off |
Create solid entities (default). |
@SplitComponents
Body |
Generate body-based component (default if
CreationType =Parts ). |
Layer |
Generate layer-based component. |
Part |
Generate part-based component. |
General |
Keep component as in CAD (default if
CreationType =TreeOfComponents ). |
@StitchingAcrossBodies
on |
Stitch surfaces belonging to different components. |
off |
Do not stitch surfaces belonging to different components (default). |
@TargetUnits
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
Supported Metadata
BODY_ID
Type | Entities | Description |
string |
Identifier of the CAD body containing the entity. Generated when
COLOR_RGB
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts |
Three RGB values, ranging from 0 to 255, indicating the color of the entity in the CAD model. Generated when |
DENSITY
double |
solids |
The value of the density of a solid. Generated when |
LAYER
integer |
Value of the layer of an entity. Generated when
LEGACY_HIERARCHY
string |
Hierarchy of an entity within a part. Generated when
MODELUNIT
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts | Model units specified in the CAD file.
This is always generated. |
ORIGINAL_ID
ORIGINAL_ID |
The original CAD entity ID. Generated when |
<name>
points lines surfs solids comps assems |
The Generated when |
