Compare Basic Input and Output
  1. Click the Manufacturing Solution tab then click Hyperform > FE Model > Basic IO.
  2. From the Solver Type drop-down menu, select a solver type.
  3. Select the HyperWorks version number.
  4. Input deck(s).
    Tip:
    • Click to search for and load additional input files. Select the top level folder to load all files of selected file type.
    • Click in the cell for each file type to activate it. Once the cell is active, click to display the file browser and load only selected files. You can also add multiple files.
    • Click to delete a selected file from the list.
  5. Select an output directory.
  6. Click Import/Export.
    Under the Step section, the following data is displayed for the Reference Model file:
    • Time to Import/Export
    • Import/Export Status (Pass/Fail)
    • Import/Export Result (Pass/Fail)
    To see the difference between the reference file (the input deck) and the HyperMesh exported file, click Status under Import-Export to display the report.
  7. Click Check Run to perform a solver check run using the reference file and the modified model file (the HyperMesh exported file).
    Under Check run, click Diff to display the solver results diff report. Here, the solver is accessed based on the availability of a license (which must be user-arranged).
Tip:
  • The message log file displays the current status of processes in progress. Click Status/Diff to display the respective report. The message log file is a text file and is saved to your output directory.
  • Click Html Report to generate an HTML report of your session information for any number of files run through the process.
