Post-processing
The solver output results are used for further design verification and validation. The accuracy of the results as processed, interpreted, and visualized by a post-processor is key. HyperView is used to post-process most of the solver(s) results. Use the Result tab to ensure that HyperView does not deprecate any result information after post-processing.
Solver results can be loaded into HyperView (in batch mode). Across different versions of HyperView, the post-processed results can be verified with previously set tolerance values. We can use the same set of reference (end-user) model and result files across HyperView versions. The Advanced Report Generation option makes it easy to quickly analyze the results.
