Auto Compare
Auto Compare allows you to do the following:
  • Verify consistency of data and command files, discover issues with functionality and API's in the complete work flow during HyperMesh interactive operations (captured through scripts)
  • Compare data (summary of model (mass, inertia, and so on)).
  • Model setup - setup material, properties, loading boundary conditions.
  • Verification and validation comparing:
    • Signature (reference)
    • HyperMesh exported solver files from scripts.
  • Spontaneously generate reference files and compare them.
  • Legacy scripts verification and validation
Reference Version (any HyperMesh version)
Use case 1
Compare any HyperMesh version output and reference files compared with output and reference files.
Use case 2
Current and reference HyperMesh versions - no reference file required.
  • Current version and reference version output and reference files are compared.
Use case 3
Current and reference HyperMesh versions.
  • Step1 - Reference version output and reference files compared with output and reference files.
  • Step2 - Current version and reference version output and reference files are compared.
Figure 3.
