Changing the Default Request Points Styling
Modify the request point type, colour and marker size.
- Select the 3D view and the result where you want to change the request points styling.
On the 3D View contextual tabs set, on the
Result tab, in the Requests group, click the
Settings icon.
Figure 1. The Request points display settings dialog. -
In the Type field, select one of the following:
- Points
- Lines
- Surface
- Next to Colour, click the colour block to specify the colour for the request points.
- Next to Marker size, move the slider to specify the size. Left to right maps to small to large.
- Click OK to apply the settings and to close the dialog.
