Display Options for Contours
View the display options for contours. Contour lines are curves that connect points where a function has identical values.
The contour display settings are available on the 3D View contextual tabs set, on the Result tab, in the Contours group.
Table 1. Display options for contours.
Icon Icon text Description
Show contours Show / hide contour lines.
Colour Set the colour of the contour to any value, or the colour is linked to the magnitude of the displayed value.
Position Specify the number of contours or the contour values.
